10-09-2022
07:51 PM
10-10-2022
12:10 PM
Dunkman
Hello,
My aunt is also with Public Mobile and she lost her Public Mobile SIM card while travelling in Europe. What would be the process in this case? She really needs to keep the same cell phone #
Thanks in advance
My Account
Service
10-10-2022 12:58 AM
10-09-2022 08:17 PM
@kaiakrol1188 if there is no Telus or Koodo stores around that carry the sim card, just order from Amazon:
https://www.amazon.ca/Public-Mobile-Card-Unlocked-Phones/dp/B07R6P5KBB
Do not order from Public Mobile online, it takes long for them to deliver
10-09-2022 08:16 PM - edited 10-09-2022 08:29 PM
Thanks all 🙂
10-09-2022 08:02 PM
Follow @Outdoorsman advice.
Make sure you let them know the SIM was lost so they don't try to upsell you another mobile plan. Might take a few stores to find a willing sales agent to sell you one.
10-09-2022 07:54 PM - edited 10-09-2022 07:59 PM
hi go to the nearest telus or koodo store to buy a new one that is the quickest way,then go ito your self serve account go to quick links and change sim number there that way you can keep your number
