number with virgin plus can activating
carlee-jones
where to check 9059977xxx
@carlee-jones wrote:
not going to Koodo Mobile.
@carlee-jones
the link works for both Koodo and PM as they both owned by Telus
Again, I checked for you and your number can be ported into PM
carlee-jones
@carlee-jones
I have checked the number for you , yes, it can be ported
You can also check here:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
You can request porting while you activate.
carlee-jones
why new number and transfer separately.
how to check my number accepted or not?
@carlee-jones  if you are asking can the number 905-997-7xxx be transfer into PM, then  YES, you number can be ported
will13am
@carlee-jones , not said what you mean?  When you activate, you can request a number transfer as part of the process. Alternatively you can activate with a new number and then submit a transfer separately.
