activation
bperry50
My wife & I set up public mobile accounts yesterday from a joint telus account - her set up proceeded ok, however I am getting a message of "unregistered SIM" the phone is a Samsung A5
bperry50
same message in her phone - will try submitting ticket - thanks for help
bperry50
yes
@bperry50   Unregistered SIM should be an issue with sim card provisioning.  Did you try your sim card on your wife phone to see if it has the same error?  if so, just open ticket with PM Support.  It is an easy fix on their side, just need to engage them with a ticket:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
RossN
@bperry50 did you both activate sepparate accounts with separate emails?
