12-18-2023
08:18 AM
12-19-2023
04:08 PM
computergeek541
Hi there,
My plan is limited to 100 minutes (100 Minutes Canada-Wide Talk), and I am planning to buy Int'l LD minutes, say 500 or 1000 minutes. How that will work out? Will I be able to use the LD International 500/1000 minutes in full? Or Will I be limited to the 100 minutes in my plan, even though it will be used for International calls not in Canada calls (which is unfair!)?
Regards,
Hugh
12-19-2023 09:28 PM
Click your browser's Back button to continue.
12-19-2023 03:49 PM - edited 12-19-2023 04:12 PM
removed a response that only repeated information that was provided several hours ago
12-19-2023 03:13 PM
Alright. Thank you all.
Now; is there any international long distance add-on that covers countries in the Middle East and North Africa, i.e. Arab countries; such as but not limited to: Morocco, Algeria, Tunisia, Libya, Egypt, Syria, Jordan, Iraq, Kuwait, Saudi Arabia, Qatar, Bahrain, UAE, Oman, and Yemen?
12-18-2023 10:48 AM
12-18-2023 10:41 AM
Canada wide minutes work in Canada only. So when you use up your 100 min transition should be seamless.
All other add-on are to call FROM Canada depend on which country you want to call.
12-18-2023 08:22 AM - edited 12-18-2023 08:24 AM
where you are trying to call? With PM service, you can only call small number of countries. You need to buy the appropriate LD addon to call the country you want. Here are the LD option:
and the 500 min Canada-Wide Long Distance - $5.00 (5 Rewards points) can only be used to call numbers within Canada. It is designed to be used for those on the $15 or $13 plans with limited outgoing minutes. If you have $25 plans and above, you would not buy this special one
