Does this count as roaming?
DDCC
Hello everyone, sorry, newbie here. I have a Canada Wide plan and was thinking to change to the Canada-US plan. Benefits are 10GB Data within Canada and the US at 5G Speed up to 250 Mbps
Unlimited Canada & US minutes and messaging plus unlimited international text and picture messaging
My question is does the unlimited Canada and US count as roaming? Will it work when I am IN the US? Or I will still need roaming?
THANK YOU KINDLY for clarification.
DDCC
Thank you VERY MUCH for the help. Appreciate it.
hi @DDCC yes, that is roaming.  but with a Canada US plan, you can use the service in US like you are in Canada, all included.  Just make sure your turn in Roaming Mobile Data when you are in US
Sansan
@DDCC  yes it's roaming. Nothing else is needed. Just turn roaming on and connect to T-Mobile or AT&T,  Verizon.
umnikke8
The Canada-US plan is designed to be used in Canada and the US. You do need to turn the roaming setting on, but there are no additional charges for use in the US.
