yesterday - last edited yesterday
Hello. New here. Accidentally used wrong account number while porting. I have raised a ticket, other than that, any way to fix this thing? Thanks
42m ago
@Kausar2024 wrote:Maybe then I have to call tomorrow and talk to them, on call, so they can look into the situation!
that's the right move 🙂
51m ago
54m ago
If you activated with a temporary phone number and requested porting from within your account then you may have more options to fix the issue.
If you requested porting during activation you will have to wait until morning to either call the porting department and/or wait for customer support to reply to you since you cannot access your account until you can recieve the one time account holder verification text.
yesterday
It was predominantly a porting request though, moving from virgin to public
yesterday
Are you porting in upon activation? Or afterwards within your account?
yesterday
There is a number to call to talk to live support. You can provide them the correct number and they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right.
But they are closed for tonight, so you will have to call them tomorrow morning.
