09-02-2023
12:55 PM
09-03-2023
10:20 AM
Dunkman
Is anyone else having problems with most incoming calls automatically going to voice-mail?
Most of my calls are set in contacts, and some aren't, but most are going straight to voice-mail. Brand new phone, no my do not disturb is not on, and no the numbers are not blocked
Service
09-02-2023 02:09 PM
Thanks.... I did notice that it was set to automatic, I'll try that.
09-02-2023 02:08 PM
No outages at all, and outgoing works perfectly and so does texting
09-02-2023 02:08 PM
No, my block is not on, and the main person it keeps throwing to voice-mail is my mother and her number is programmed into my phone
09-02-2023 02:07 PM
No, I've been with pm for almost 3 years with the same phone number
09-02-2023 01:16 PM
Check to see if there are any outages in your area. Refer to outage map:
09-02-2023 01:08 PM
OH. Another thing is that I just experienced recently myself. I have the iPhone and I went into my settings so I can block unknown numbers. That seemed to send a lot of peeps over directly to my voicemail including my doctors office. You may wish to check if that is set up. If it is, remove it. I know it will suck getting calls from unknowns but... eh....
09-02-2023 01:00 PM - edited 09-02-2023 01:24 PM
Is there any chance that you recently ported over a number? I know some other members have run into a similar issue when their port was incomplete. Can you make outgoing calls and texts?
If you did recently port the number, did you respond “yes” to a text sent to your old SIM authorizing the port to take place?
09-02-2023 12:56 PM
This is worth a shot. Try going in to network settings, turn off automatic and then pick Public Mobile then reboot. And then ask a person who's call went to voicemail to try calling you back.
