voicemail
Harb77721
phone not going to voicemail when not answered
Meow
You have to set up vmail and to do that very first time you have to use your mobile phone. After that you can access vmail through mobile phone or from any other phone. Initial set up cannot be done using 'other' phone calling access number.
Chalupa_Batman
Hi @Harb77721
To add to @dust2dust , did you set up voicemail? I know that sounds stupid but some think it's automatic. Also, do you have your phone set to ignore unknown numbers?
dust2dust
iphone or Android? Do you know if your phone has been enabled for volte yet? What about when you choose to ignore the call? What about when you're on a call?
