Inactive email
Inactive_email
The email that I use is no longer active and there is no change email option. I cannot login to my Account and pay for my plan. Is there anything that I can do?
Yummy
Using existing email you can still log in into your account and pay the bill.
Your existing (inactive) email is actually PM's login ID. No matter if it is still valid or not!
In the mean time you can contact agent to change your email.
- Send a private message to the CSA - agent by clicking Here
HI @Inactive_email    For now, when you login, you can try to have the 2FA to send to your phone instead of your email.
Once you get the code, you use the "old" email address as the username to login  to update your plan
Of course, you still need to change to the proper email address, you will need to open ticket with PM CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
RossN
@Inactive_email
hi contact a cs agent to change email
1.  you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
hairbag1
Dial 611 to pay with your on-file credit card ore get payment vouchers at Shell Gas or Walmart..then dial 611 to add 'em to your acct.
