07-21-2022 09:25 AM
so if I order the USA data add on it will start automatically unlike the old system where you put in a start date in, if I remember correctly
07-21-2022 09:35 AM
Correct. US add-on starts immediately after purchase. Ideally will be to purchase it close to the border.
07-21-2022 09:27 AM - edited 07-21-2022 09:31 AM
It starts as soon as you load it successfully and last for 240 hours (or 10 Days) Only works whilst in USA.
edit..Your data is limited to the amount you buy...but still only available for up to 240 hours.
07-21-2022 09:27 AM
@Willaug56 hi yes it starts right away and lasts for 10 days
