If I Change my plan, does my rewards (Loyalty & Subscription), transfer to new plan?
nur_gillani
CharlieWhisky
Yes, you keep all your rewards and loyalty 😀
HI @nur_gillani changing plan has no effect on your rewards, so  you will still  have the same rewards saving every month
hairbag1
@nur_gillani
yes...just don't opt for POints...ever !
