11-08-2023
06:25 PM
11-09-2023
09:33 AM
Dunkman
I currently have 3G Plan @ $25/month.
I want to change to the 4G Plan @ $34/month.
I would like to know the following
1. I am currently on the old rewards program and would like to keep it that way. Will it change to the new program or do I get to keep the old program?
2. I have with existing plan, the following add ons. Will I get to keep them or will they be lost?
A. 2x 2G Data bonus
B. 1000 International Long Distance minutes
C. 1000 Canada Long Distance minutes
11-21-2023 10:31 AM
Was that a claim from support? I think we would all agree that that is 1/3 true. The only time data add-ons become incompatible is on 5G unlimited plans. Data add-ons will still work and be switched over to the 5G roaming plans and all 4G plans. (and of course 3G plans)
11-21-2023 10:20 AM
An Update.
The data add on are NOT compatible with the 4G & 5G subscriptions. But the extra long distance minutes add on are switched over to the new plan.
Thanks,
11-08-2023 09:42 PM - edited 11-09-2023 09:38 AM
You'll keep the old rewards and add ons.
The plan bonuses are YMMV. Depends what the original terms stated when you got them.
ADDING: @edinez1 To protect yourself, ask the customer support agents ahead of time and screenshot their response.
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
