Losing Add-On Data if Subscription Change
Spud_18H
Is there any way for me to know in advance if I will lose add-on data that I purchased using rewards if I change my subscription?
2 REPLIES 2
Spud_18H
That's great - thank you for the info!
@Spud_18H
you won't lost add-on data if you change subscription.
However, please be aware that data addon has a 30 days expiration.  Also, when a new cycle starts or when you starts with a new plan, PM system is set to use the data from the new cycle/plan first, so the data left in the add-on likely be wasted.
So, if you are buying or redeeming data add-on because you ran out of data, please only buy/redeem enough data for use from the time of the purchase to the upcoming renewal date.
If you are planning to make plan change anyway, I suggest you to simply use Change Now option to make an immediate plan change so you can use the data from the new plan immediately
