I want to pay my plan, please, help me.
Maximiliano
I don't sign in my account, you let me subscribe, went I try subscribe, you say me, you are subscribed yet, please help me, what should I do?
2 REPLIES 2
dust2dust
Are your services working? You can pay by logging in or using 611 with your 4 digit account pin or buying vouchers and using 611 but not need the pin or using the RTR choice at muskbird.com or using the instant top up method in a few stores.
Chalupa_Batman
Hi @Maximiliano
There seems to be a language barrier here but I'll try my best. You can pay your bill through your profile and subscription section. You can also use a PM Voucher which you buy at Shoppers Drug Mart and then you call 611 to put it in. Does that help?
Ciao @Massimiliano
Sembra che ci sia una barriera linguistica qui, ma farò del mio meglio. Puoi pagare la fattura attraverso il tuo profilo e la sezione abbonamento. Puoi anche utilizzare un voucher PM che acquisti presso Shoppers Drug Mart e poi chiami il 611 per inserirlo. È d'aiuto?
