Can-US-Mex 75gb plan
12-26-2024 10:23 AM
Hey all:
Does anyone know if the 75gb plan will increase in price after a set amount of time? I didn’t see anything when I switched, but I just noticed Freedom is advertising a similar plan but the pricing is only fixed for 18 months.
Plans
12-27-2024 12:13 PM
12-26-2024 10:52 AM
It should be further noted @h3adgskt , that any mobile service provider can, with 30 days notice, change the pricing of in-market plans it offers.
To my knowledge, this has only happened once in 10+ years when they increased the no-longer offered $10 plan to a $13 plan a few years back.
The move prompted many subscribers to simply jump up to the $15 plan, which is likely the reason Public Mobile made the move.
12-26-2024 10:44 AM
I noticed a plan like that recently but couldn’t find any fine print for this one. Thank you for clarifying!
12-26-2024 10:38 AM
PM normally never increase the price of the plan you are locked into.
I was on the $25 plan for 2 years until I decided to switch to another plan.
12-26-2024 10:29 AM - edited 12-26-2024 10:30 AM
Once subscribed to a plan, it's unlikely that Public Mobile will increase the cost of the plan, @h3adgskt
An exception would be in the event they advertise the plan as a limited time only savings, which is pretty rare around here.
