10-01-2022 08:42 PM
My plan renewable date is 12th, I upgraded my plan on Sep 1th1 but it is still showing the previous plan as my current plan, but I just realized I was charged for the upgraded plan. How can I get a refund for the extra that charged from me?
10-01-2022 09:07 PM
Yes, you both are correct, it is showing the correct one in a private mode. But I feel Public Mobile should issue a refund of extra money I paid for the upgraded plan because I didn't use any mobile data since as I thought upgraded plan didn't happen. Do you know how I connect with a real agent on Public mobile?
10-01-2022 08:58 PM
It is a known glitch the last couple of weeks. When customers change plans, it showed the old cached version plan, even though your plan was changed/upgraded. Public mobile is aware of the issue and figuring out a fix.
As mentioned, if you check your account with a new web browser, cleared cache or incognito mode, it should show the right details of your upgraded plan.
10-01-2022 08:46 PM - edited 10-01-2022 08:46 PM
@dayanath Hi you are probably seeing a cached version of your account, delete your cache and cookies or use a different browser in private or incognito mode reboot your device and sign back in to your account,see if it updates
