10-01-2022 02:09 PM
I got a new samsung galaxy cell phone and the sim card from my old samsung galaxy phone wont allow me to make call or text. its not the phone as my friend put his sim card in my phone and it worked fine. do i need a new sim card?
10-01-2022 09:13 PM
call Samsung to unlock the device for you
10-01-2022 08:52 PM
@Rustyhfx wipe the sim card clean once more and try to put the sim in both your own phone and your friend's phone.
If both shows no network, no sim, then It could really be a faulty sim card problem
But first open ticket with PM Support. They will ask you to do similar troubleshoot steps, follow them. if they also come to the conclusion that it might be faulty sim, you can ask them if they can reimburse the charge of a new sim card.
To open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
10-01-2022 08:38 PM
Well that's weird?
10-01-2022 08:37 PM
model is samsung galaxy j3 orbit - with single sim card
only msg is no sim card and no network
10-01-2022 08:34 PM
yes still works in my old phone.......its a samsung galaxy j3 prime
new phone is samsung galaxy j3 orbit same as my friends phone. does not work in either phone.
msg comes up as no sim card and no network
10-01-2022 08:31 PM
my sim card did not work in friends phone!
10-01-2022 02:59 PM
trying take out sim and put it back and reboot phone, not works,open ticket with PM support and ask them to check it for you
have trouble with Chatbot: Private message CS_Agent
10-01-2022 02:34 PM
@Rustyhfx what is the model of this new phone? A single sim phone or a dual sim ?
Isnthere any error message on the phone status bar?
Did you try Reset All Network?
10-01-2022 02:29 PM
Does it still work in your old phone? Is it the correct size? Check it for any dirt or debris and you can clean it gently with a cotton swab and a little isopropyl alcohol. Make sure it fits snugly in the Sim slot of your new phone so that the contacts connect correctly.
10-01-2022 02:20 PM
@Rustyhfx Did you also try your SIM in the friend's phone to see what happens?
