11-29-2021 12:08 PM - edited 01-06-2022 04:05 AM
12-03-2021 06:31 PM - edited 12-03-2021 06:32 PM
i was to suggest CS agent.. but people have been laughing me for asking too much.. and I guess I should even say too much
oops.. by the way.. i am answering your question .. did I tag you? 🤔
(and I can't believe you VIP member make this joke.. LoL)
12-03-2021 06:29 PM
Lol...I can't believe no one even suggested contacting customer support. Someone--Surely missed this thread!😁
12-03-2021 05:19 PM
@wahid123 "didn't port from any other service , I just purchase a new SIM card and select new new from public mobile website and activated"
If you still have this glitch it suggests you have only partial activation, so you likely need assistance from the moderators.
To get a ticket click https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question into SIMon. Invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear. Click it then login and pick the topic, if needed, from the drop down menu. To confirm your ticket has been submitted, check the SENT box in your private messages; click the small envelope beside your avatar at top right on your screen.
11-29-2021 02:11 PM
@softech wrote:
@CountyDownIeUk wrote:
@softech wrote:
@wahid123 wrote:I didn't port from any other service , I just purchase a new SIM card and select new new from public mobile website and activated it , now I can do messaging and outgoing calls but I can't get incoming calls ?
You pick a new number from the list ?
did you try calling that new number you picked from a landline (or another phone)?
Where else would you pick a number from if you did not port?
@CountyDownIeUk I just want to confirm OP is really getting new number and not porting.
Incoming calls issue usually caused by porting
That had already been confirmed.
But I also ask OP if he called the number.. you know why? I just want to confirm if Telus did give out an existing number to new user
Ohhhhh yes...I completely understood that !!! But since you left that part out would have the OP?
this is my style of helping user to troubleshooting together. The question was not to ask you. You can leave it if you do not like my style of helping user
This is my style to help the OP with a non informative response.
11-29-2021 02:02 PM - edited 11-29-2021 02:03 PM
@walker1 I apologize for misread your reply 🙂
11-29-2021 02:01 PM - edited 11-29-2021 02:03 PM
My reply wasn't for you or else I would have tagged you. If you didn't like it, you can just leave it alone. That's my style.
No need for you to reply back 🙂
11-29-2021 01:51 PM - edited 11-29-2021 01:54 PM
@walker1 wrote:You can pick a new phone from the air, but it most definitely won't receive any calls.
@walker1 again this is my way of confirming user did not port number. I understand user did said he didn't port , but no harm to confirm. Only incoming calls not working usually is an issue with porting.
But I also ask OP if he called the number.. I just want to confirm if Telus give out an existing number to new user
11-29-2021 01:49 PM - edited 11-29-2021 01:54 PM
11-29-2021 01:41 PM - edited 11-29-2021 01:44 PM
11-29-2021 12:34 PM
11-29-2021 12:27 PM
11-29-2021 12:26 PM - edited 11-29-2021 12:26 PM
Reboot your phone and then dial your phone number. Does it go to your voicemail or does it go to someone else's or does someone else pick up? Its possible you choose a number that was accidently released but is already in use by another telus/koodo/pm customer. If this is the case you will have to choose a new number by logging into your self serve account and clicking on change number. You can change your number up to 4 times every 30 days.
11-29-2021 12:24 PM - edited 11-29-2021 12:50 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,
if you can't fix it you can test your SIM card in another device to you can know the issue from your SIM card network or your device.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck...
11-29-2021 12:21 PM
You will have to put your old provider sim card back in your phone to reply YES to the PAT (porting authorization text) within 90 minutes of receiving it. If you are still within that time window because you just finished activating then do so. Otherwise call the telus porting department number that @softech sent you with your old provider's account # so you can have them reinitiate the port request.
Good luck and welcome to public mobile!
11-29-2021 12:19 PM
11-29-2021 12:11 PM - edited 11-29-2021 12:11 PM
outgoing calls working and data working?
you activated and porting in your old number from another provider? if so, did you reply the sms from our old provider to approve the porting within 90 mins?
I will message you the porting team number, you can call them for status update. Please check your community inbox , envelop icon on top right
