09-10-2024
05:09 PM
09-10-2024
05:13 PM
computergeek541
09-10-2024 05:22 PM
If restarting doesn't work, you will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
09-10-2024 05:14 PM
@ElipheD wrote:my phone is stuck in s.o.s mode
There could have been a network outage in your area. Does restarting your device help reconnect you to the network?
