3 hours ago - last edited 3 hours ago
3 hours ago
@Mary27, so it sounds like you did a "Change now" instead of a "Change on renewal". Change now will forfeit any remaining days left on your existing plan and start the new plan immediately. You'll need to open a ticket through the Chatbot to ask the CS_agent if he can change it to a "Change on renewal instead", not sure if they will but they're the only ones that can make account changes.
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
3 hours ago
@Mary27 Try this direct link to support it will work
3 hours ago
No I only have one account and paid for two when switching to my current subscription. Also the ticket process is malfunctioning.
3 hours ago
hi @Mary27 so, you have 2 accounts with PM and you tried to pay both accounts but added money to the same account?? PM usually does not move funds from one account to another, I doubt they will do it, but you can ask and hope for the best
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
