11-28-2023 09:36 AM
I ordered a SIM card, but is it possible to change the shipping address?
11-28-2023 10:23 AM
Got it, thanks
11-28-2023 10:07 AM
@Sansan wrote:I'm also wondering if you sign back into the account, is there not a way to look up "orders or tickets" pending? If so, maybe you can change the address there?
@Sansan - you can look up tickets sent to CSA through your community envelope. But SIM card ordering is a different system/log in credentials.
The address in your My Account is only for current customers. People who are not customers yet, do not have a My Account. Regardless, the address in My Account should not be used for shipping address. If anything that is most important for billing purposes upon activation.
11-28-2023 09:46 AM
11-28-2023 09:43 AM
@Youngwoong You would need to contact support and see if it can be done last minute . But you can also buy one from Telus Koodo store also
send a private message To CS_Agents click
VVVVV Link below VVVVV
11-28-2023 09:40 AM
HI @Youngwoong
if it was just today, then maybe still doable. please submit a ticket with CS Agent here:
11-28-2023 09:39 AM
@Youngwoong - did you JUST order it? If so, than try sending a message to Support, see below.
Connecting with Public Mobile Customer Support (CSA) - go to your ENVELOPE at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the pencil inside it to start a new message. Type CS_Agent in the SEND TO box. This will create a private message to Public Mobile Customer Support.
