11-23-2024 05:28 PM
I want to buy a replacement SIM. I need a physical SIM because my phone won't work with eSIMs.
I went to Profile and clicked Shop SIM card now. I selected SIM Card ($10) and I copied the address in my profile and put that as the shipping address. When I try and pay, I get the messages:
Invalid address
Your selected address doesn't match the one in your profile. Select this option if you'd also like to update the address in your profile.
Obviously, this is a malfunction in the system because I actually copied and pasted the address in my profile.
Can anyone assist?
Thanks!
11-23-2024 05:44 PM
hi @Christine_H don't buy from PM online, buy from Telus or Koodo or Mobile Klinik store, it's quicker, or buy from Amazon
Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
11-23-2024 05:34 PM - edited 11-23-2024 05:35 PM
@Christine_H With Canada post strike I would just go pick one up from Telus Koodo store or order one from Amazon $4.99 there right now be much quicker . Even at best of times SIM cards from public mobile can take as long as 3 weeks to arrive
Find SIM card Find a store near to you | Public Mobile
Amazon
11-23-2024 05:31 PM
I also selected the option to update the address in my profile and it still didn't work..
