11-02-2024 12:56 PM
I'm trying to order a new SIM card and it say's my mailing address is invalid?? They most certainly sent the first one here. When I checked my profile there was no address listed? I tried to re enter but keeps saying it is invalid??
11-02-2024 01:53 PM
Thank you @Handy1 that worked. The first time I tried it it seems I had it upside down and my friend told me they were different> . ( Idiot) So I swapped to the XR and everything 100%.
Interesting find. I put the Mexican Telcell SIM in the old iPhone 7 and It connected to Rogers. I made a call to test and Telcell just texted me with the link to top up my pay as you go! So my old phone becomes a cheap pay as you go with a Mexican Phone number, cool.
Thanks everyone for you help. You saved me $10. Public Mobil is like Flair Airlines. Cheap but no on line service.
11-02-2024 01:26 PM - edited 11-02-2024 01:31 PM
@cactusmusic Public mobile is pre paid service = pay as you go
adding @cactusmusic @Chalupa_Batman Gave you the link in his reply to amazon with Public mobile SIM card for $4.99
11-02-2024 01:25 PM
I looked on Amazon and those are all pay as you go. I submitted a ticket asking for them to fix the address issue.
11-02-2024 01:12 PM
@cactusmusic You old sim will still
work just snap off outer edge
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
11-02-2024 01:12 PM - edited 11-02-2024 01:16 PM
Strange that the iPhone 7 and iPhone XR has a different size SIM. They both should be Nano size SIM. Make sure you match up the 45° cutout one corner to the SIM tray.
11-02-2024 01:10 PM
Thanks for the heads up. A friend just gave me his old iPhone 10 XR, my old phone is a 7 so the SIM card is different. I was just in Mexico and got a free SIM card, 1 GB data and unlimited talking for $8.00 From an Oxxo ( 7-eleven) We are being ripped off in Canada. I'll go check out the Amazon. TNX
11-02-2024 01:01 PM - edited 11-02-2024 01:02 PM
On your account PM only refers to your postal code but contact a CS_Agent to help you with the address issue. Click on the Chatbot and type in Submit a Ticket or Contact Agent.
I would suggest you not order the SIM for PM as there is a possible Canada Post strike so it will take awhile for you to get your SIM for possible Black Friday deals from PM.
I would suggest you order the SIM from Amazon for $5 or pick one up from your local Telus/Koodo/Mobile Klinik store for $10.
11-02-2024 12:58 PM - edited 11-02-2024 12:59 PM
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
If you try ordering it from Public Mobile it can take up to 3-4 weeks by Canada Post with no tracking number.
@cactusmusic Be much quicker to buy one from Telus /koodo store or Oder from Amazon is fast shipping and only $4.99 there right now . From public mobile it can take up to 3 weeks to arrive anyways
