02-03-2022 05:15 PM
Hi,
I have one phone but two different credit cards are being charged a monthly fee.
02-03-2022 06:07 PM
You can have only one CC registered with one PM account.
Did you try by any chance to activate your PM account twice using 2 different cards?
Unless somebody is using your second card and you do not know...
02-03-2022 05:40 PM
You can only input one CC per one account.
Login to your Self Serve account to see which CC is on your account.
02-03-2022 05:33 PM - edited 02-03-2022 05:39 PM
If you had activation issues as per @softech 's scenario then you will need to contact customer support to issue a refund to the card that is not registered to your account. Have a copy of your credit card charges to show the CSA to arrange the refund and ensure it is no longer charged.
02-03-2022 05:26 PM
@strathfoodprogr Two different credit cards? Sound like it shouldn't be. PM would not have info for your 2 cards.
Did you just join PM for a month or two? Did you recall any activation issue and you have to re-attempt activating a second time with another credit card? If that was the case, then that could be the only reason I can think of that PM will have your two credit cards info
02-03-2022 05:22 PM
check with family member maybe someone use for new line and you don't know about it,
or get in touch with Customer Support Agent (publicmobile.ca)
02-03-2022 05:22 PM
@strathfoodprogr wrote:I have one phone but two different credit cards are being charged a monthly fee.
On your online credit card statement page, is one listed as pending and one as posted? For my bank, it sometimes shows an authorized charge that doesn't immediately fall off right after the confirmed charge is posted.
