05-08-2024
10:43 PM
05-09-2024
08:24 AM
computergeek541
05-08-2024 11:12 PM
@Melviticus so, you should try to uninstall the app, reboot and reinstall the app and re-puchase the esim on the app
again, if still cannot buy or install esim, please open ticket with support agent
05-08-2024 10:57 PM
It is a new iPhone 15. When I go through the eSIM purchase, the final screen does not allow me to click “buy and install”
05-08-2024 10:47 PM
@Melviticus wrote:
- Hello, I have downloaded the app and gone through the purchase procedure but the final button to click “purchase” doesn’t seem to work.
- please advise ASAP
are you repurchasing the sim on the same old phone or on a different phone?
What phone is that?
while you can try to uninstall the app, redownload and rebuy esim once again, but I suggest you to open support ticket and ask agent to check if the purchase was completed successfully and see if they can email you the QR code to install
05-08-2024 10:47 PM
@Melviticus - Please contact CS_Agent:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
