08-26-2023 05:30 AM
Hi Public mobile,
Since I lost my mobile phone and I couldn't get my log-in code.
08-26-2023 10:03 AM
Hi @Kennis
No need to contact a CS agent yet IMO. Here's how you can send the 2FA code to your email.
Can’t get the 6 digit 2FA code to your phone? Try this method
First, sign into your account at www.publicmobile.ca and use the email you signed up with and the password. If it asks you for a 6 digit code, it will say at the top left CONFIRM YOUR IDENTITY.- Enter the 6- digit code sent to *********. But it’s not working!!! As you see by the screen shot below, 1. Click the This is a trusted device. 2. Didn’t get the code? Click on that.
Then, the next window that pops up is this.
Choose "Send email". This will send the 6 digit code to the email you registered your account with. NOTE: DO NOT cut and paste. Enter the numbers manually.
Let us know if this works. Then we'll help you further with your needs.
08-26-2023 08:13 AM - edited 08-26-2023 08:14 AM
If you are able to verify your Account details with the Customer Support Agent and send them the your new SIM Card Number, they'll be able to Activate it from the backend for you.
Than when you sign in, you'll be able to get the code to your Number on the new SIM Card, everytime after the first sign in you'll have an option to alternatively 'Resend the code' to your Email.
'Contact a Customer Support Agent'
08-26-2023 05:55 AM
@Kennis Message support to help you
private message To CS_Agents click
VVVVV Link below VVVVV
