complete device set up
Sandra55
I am not able to receive the 6 digit security code to the phone number I provided
Priority
So the code is sending to the Number you Ported into Public Mobile, correct?
Sandra55
I have tried this several times I can receive only email when I try to set up phone number it requires a six digit security code by text which I can’t receive
Sandra55
This option does not come up for me. They have send text or voicemail only
Sandra55
I just transferred my existing number
Priority
Did you just sign up, did you select a new Number from Publics Pool upon sign up, or did you Port your number in recently?
HI @Sandra55
on the security code screen, click Didn't receive code and the Send email option will be there
