I just transferred yesterday and cannot get calls or texts
Jem1988
Help please I just transferred my number from lucky to public yesterday and since than cannot receive calls or texts
2 REPLIES 2
@Jem1988  Sounds like porting was not completed did you leave the lucky SIM card in phone to reply YES to confirmation text ? No worries thou I’ll send you porting team number private message right away . Call then and they can re trigger the port request for  you
TheSterlinger
The porting process was unsuccessful I will send you the number check your messages click your avatar and click inbox.
