03-17-2023
10:47 PM
03-18-2023
12:39 AM
computergeek541
03-18-2023 12:40 AM
@Simonsung wrote:Confirmed and it says unlimited minutes but when I tried calling, it says I have used up all my minutes. Where is the chatbot link?
If you dial a 1 before the area code, can you place calls?
03-18-2023 12:06 AM
Thanks will try that.
03-18-2023 12:05 AM
Tried that already
03-17-2023 11:22 PM
you tried to power off the phone for 5 mins first?
In case you need chatbot to open ticket, or message support
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-17-2023 11:19 PM
03-17-2023 11:19 PM
Can you try the sim in another phone?
03-17-2023 11:16 PM
03-17-2023 11:16 PM
Tried and it didn’t work.
03-17-2023 10:51 PM
@Simonsung Try turn off your phone for 5 mins, then restart it and see if it works again
03-17-2023 10:49 PM
@Simonsung , that does not seem right. Just to be sure, please check your account using incognito mode on the browser to make sure you have a plan with unlimited calling. If the plan is confirmed and you are not able to complete a call, then initiate a support ticket using the chatbot link and have the account looked into.
