03-21-2025
09:04 AM
03-22-2025
12:07 AM
computergeek541
My plan says unlimited Canada Wide minutes but will not complete a call due to using all available minutes. The recording says I should buy more minutes
03-21-2025 10:15 AM
Try to reboot your phone (turn off/on), pull sim out, wait a bit, push it in and try again.
For some reason some customers do get this message and if you want to find out why, open a ticket. Maybe agent will have an explanation and solution. Then let us know what was the answer.
03-21-2025 09:08 AM - edited 03-21-2025 09:09 AM
hi @Mitmat
it is very common false alarm. Usually you just need to reboot the phone and it will work again
if not, you can try to call by putting a 1 in front of the 10 digits number. If already using a 1 , then try just calling the 10 digits only without the 1
