01-18-2024 06:31 PM - last edited on 01-18-2024 07:30 PM by computergeek541
hi there. I am interested in changing my plan to the promo $24 dollar plan which has 4G data. Currently I have the $15 plan. Would that be possible? Also if this change can be done, will I loose my loyalty $$ off every month? Thank you!
01-18-2024 07:12 PM
When you contact Customer Service, make sure you are asking to upgrade to the 4G plan nicely. If they respond positively, one of the agent will contact you via your community account email. So, make sure to check this account frequently. If they offered to upgrade, tell them to upgrade immediately to lock in the offer. You will keep your legacy dollar discount. Good luck
01-18-2024 06:47 PM
@hTideGnow wrote:hi @Shirazr
The plan is for new activations only.
But you can check your luck with PM agent. please submit a ticket with CS Agent here:
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437Remember, that plan supposed to be for new activation, so agent has the right to decline your request, although some reported they got it.
If at first you don't succeed...try, and try again.
01-18-2024 06:33 PM
hi @Shirazr
