I got U.S roaming add on didn’t really work
08-06-2019 10:11 AM - edited 01-05-2022 06:17 AM
Yesterday we went to the US for shopping and some dinner. When I added the 250MB data roaming addon it didn’t work and was VERY spotty. We got lost in a foreign country because the data was unreliable and the GPS on my phone gave up half way through trying to get back to Canada. Not cool. Basically a giant waste of $10. It also shows data was used which is laughable. If I wasn’t on wifi my internet Did NOT work and pages wouldn’t load.
07-22-2022 11:06 PM
PM partners with T-Mobile and AT&T for US roaming. The US shutting down of 3G will affect the use of Voice roaming.
You would have better chance to get the voice connection you need with T-Mobile. But use manual selection (for T-Mobile) instead of letting your phone to automatically select it for you. Let us know how it turns out
07-22-2022 11:01 PM
No I did not try that. I was in northern Michigan. I didn’t know I needed to change the carrier to that specific one. Thanks for the tip
07-22-2022 10:59 PM
07-22-2022 10:58 PM
@Kdh- Talk is very much in flux these days. Text should have worked. Did you connect to T-Mobile?
07-22-2022 10:56 PM
The talk and text did not work for me as well.
08-06-2019 11:04 AM
We had the same issue 2 weekends ago. Very frustrating.
08-06-2019 10:46 AM
Even if it was unreliable, you were still using the data, and 250 mb isn't a lot so it likely got used up. The data usage won't stop just because the signal's not great.
Sorry to hear about your experience, though, and I hope the mods can provide some assistance. My wife and I used the add on in May when we were driving down to NJ from Canada and it worked without a hitch, but stuff happens.
08-06-2019 10:16 AM - edited 08-06-2019 10:31 AM
@Addicted2fishin wrote:Yesterday we went to the US for shopping and some dinner. When I added the 250MB data roaming addon it didn’t work and was VERY spotty. We got lost in a foreign country because the data was unreliable and the GPS on my phone gave up half way through trying to get back to Canada. Not cool. Basically a giant waste of $10. It also shows data was used which is laughable. If I wasn’t on wifi my internet Did NOT work and pages wouldn’t load.
@Addicted2fishin Best to contact the PM moderator for these types of issues.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
