07-22-2022 08:43 PM
I can't receive local long text messages
I have data
and unlimited messages in my plan
I did not experience this issue before the message shows as downloading for an hour now
Service
07-22-2022 11:29 PM
I would try to update the 2 lines:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
Save and reboot and see if it works
07-22-2022 11:25 PM - edited 07-22-2022 11:34 PM
All done thank you
07-22-2022 10:38 PM - edited 07-22-2022 10:45 PM
@diyala wrote:
I did add this point according to the instructions i recieved from the robot chat and restarted after wards
Still not working
You've entered the MMSC incorrectly. It needs http:// with the doubleslash to be an exact match.
http://aliasredirect.net/proxy/mb/mmsc
You will need to restart after editing the APN.
The download placeholders for MMS attachments already sent to you may or may not be lost forever. But subsequent MMS communications should work properly (with the proper APN syntax) moving forward.
07-22-2022 10:09 PM
Still not working
07-22-2022 09:56 PM
Cellular data needs to be active. "MMS Events" are logged on Self-Serve usage, though they consume 0.000KB of billable data provision.
Beware that updates, syncs, telemetry, and background apps might consume your billable data whenever it's active. If this is a problem then you'll have to go through settings and permissions for these apps to curtail this behaviour. Smartphones have built-in software to monitor and track data usage, it can be used to inspect where all your data is going.
The phone needs to have Public Mobile's APN settings. Some phones (with older Android OS versions) specifically require "APN Type = default,mms".
The messaging app itself must support MMS and have the relevant permissions (photo album/gallery/preview, camera, cellular data, etc) enabled. Some messaging apps (like iMessage, RCS, and Signal) support extended features which can override standard SMS/MMS protocols - these apps invariably have a setting somewhere which allows these extended protocols to be disabled.
Restart for changes to take effect.
07-22-2022 09:32 PM
I used to be able to receive mms on the same phone no issues
I tried to reset my setting and did not work
07-22-2022 09:21 PM
I tried adding APN point and restarting
nothing worked
07-22-2022 09:20 PM
xaomi red me 10 pro
07-22-2022 08:48 PM - edited 07-22-2022 08:48 PM
Check to see if MMS and Cellular Data setting are both enabled.
What is the make and model of your phone so we can help you step by step?
07-22-2022 08:45 PM - edited 07-22-2022 08:47 PM
@diyala - is your Data option turned on in the settings of your device when you try to receive or send 'long texts'? It is treated as an MMS, like a picture text.
Edit: if your data is turned on.
Try:
- restarting your phone
- perform a reset of your device's network settings
- try your sim into another compatible phone to see if long texts send/receive
