Looking for help!!!
lidi
Looking for help. I switched from Virgin, but I can't receive calls or send and receive text messages these days. I can make calls and surf the Internet normally.
1 REPLY 1
Techfish
Your number may not have fully transferred. I would recommend re-sending the request or contacting a support agent who could help you.
Here's a link you could use to message an agent https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
