03-02-2023 05:40 PM
Hi there,
Something very weird happened today. I couldn't make a phone call to 1 (866) 523-4357. A perfect legit business number. The call was immediately disconnected from my side saying invalid service . In the meantime I could reach the number from tmy other phones. Tried to change my Android phone settings. Disable call blocking. Adding the number to my contact. Nothing helped.
03-02-2023 10:52 PM
Can you call any other number? Try this test call number: +1 416 342 9562. If that call doesn't go through, I wonder if the 3G network service is working in your area, which is required for voice calls -- texts & data will use the LTE network.
In your phone's network settings, see if you can force 3G only mode and see if you get any service at all... Are any of your other phones that worked also with Public Mobile? if this is the reason, it would affect all of them... But other carriers may not be affected...
03-02-2023 09:13 PM
HI@ecroft have you submit a ticket with CS agent yet? I see many have reported the issue today, and couple of them confirmed working again later
please submit a ticket
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-02-2023 09:09 PM
I have tried all of these things and have the same problem. Nothing seems to be helping :'(.
03-02-2023 09:08 PM
Calling that number also works for me (from Regina, SK)
03-02-2023 06:42 PM
It sure looks like there are strange things happening with the calling feature. Fortunately I am able to call that toll free number.
03-02-2023 06:14 PM
HI @DDM69
you are ok but not your wife's? So, it looks like this "outage" is account based and not location
let us know when PM fixes that for you and tell us what they tell you about what happened
03-02-2023 06:08 PM
My wife's phone had the same issue. My phone worked fine. Troubleshooting didn't resolve anything. Had to submit a ticket.
03-02-2023 05:47 PM
@wzhou6 - that is weird. I was able to call TD at the number without issue.
Are there other numbers you are not able to call?
Try restarting your phone, and /or perform a reset of the device' network settings.
Sometimes if you remove the SIM Card, put it in another phone, restart that phone, then move the SIM card back to your phone (restart it), this can help with network/account issues. Try this.
