11-25-2023
08:42 AM
11-26-2023
12:04 PM
Dunkman
Just got this message. what should i do?
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
11-25-2023 08:44 AM - edited 11-25-2023 08:45 AM
@Moran did you provided PM the IMEI instead of old provider 's account number?? Please update them with the account number instead
There is a number to call to talk to live suppoet and update the missing info. They can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
