3 hours ago
3 hours ago
Yes, you can do it through My Account
3 hours ago
you can change your number by logging in to your account / Profile / Current Phone NUmber...then click the little pencil icon. There, you can change the number.
3 hours ago
what is your problem with change number?
if you need to change number, just go to My account, Profile, click the pencil beside the number and you can change number
