03-02-2024 09:56 PM
Hi there,
So I can't seem to send pics when I text.
Is there a way to fix it?
Thank you
Service
03-10-2024 12:58 PM
It worked. Thank you so much!
03-03-2024 05:10 AM
It works now!!! Thank you so so very much! I really appreciate it. Your the best!!!
03-03-2024 03:42 AM
Restarting your device just reboots the OS and powers up your phone. Your apps will still be in place.
03-03-2024 03:41 AM
Why is my post listed as an "accepted solution"?? I'm actually asking a question.
03-03-2024 03:38 AM
Is there a way I can reboot my phone without deleting my apps, texts and music on YouTube music?
03-03-2024 03:30 AM
Are you able to tell us how we accomplish this on an iPhone running iOS 12? There is no setting beyond the APN server name.
03-02-2024 10:32 PM
Thanks @Quincy1
Personally, I see both 4D4F and 4D for MVNO value. I think both work
03-02-2024 10:07 PM
Ok check the settings to see if they match and if not delete and enter again, reboot phone.
03-02-2024 10:05 PM - edited 03-31-2024 08:32 PM
did you just update the OS to Android 14? There has been some issue with OnePlus after the Android upgrade
With OnePlus, there might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
03-02-2024 10:05 PM
I just updated my phone a few days ago with the latest software and it was working before I updated it. I'm using a One Plus 11
03-02-2024 10:04 PM
I was working a few days ago until I updated the latest software on my android. My phone is a One Plus 11
03-02-2024 10:03 PM
what phone do you have?
your phone might be affected by this announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
03-02-2024 10:03 PM
HI @Yossy107
PM just updated the MMS system. Phone older than 2015 won't have MMS support anymore. How old is your phone?
03-02-2024 09:59 PM
What type of phone do you have? There is a message regarding apn settings on phone prior to 2015.
Check see if this could be why.
