11-06-2023 09:54 AM
I can't activate to port out number from TELUS to Public Mobile. The number keeps getting invalid Canadian number. And even if I choose another number, there's always issue to activate. Please help as the Public Mobile already deducted my money. Thanks
11-06-2023 10:07 AM
Somehow, I can't even get a temporary new number as it keeps failing activate the esim. Is there any QR code supposed to send by email? I never received any email for QR code
11-06-2023 10:04 AM
Hi, I just put in the ticket with the agent. Thanks
11-06-2023 10:04 AM
I used the app but always stuck on step 5 as I can't transfer number. It keeps saying the number is invalid Canadian number (I used this number for 10 years already).
11-06-2023 10:02 AM
Thanks so much. I just send them the message now.
11-06-2023 10:01 AM
hi @lehuutai130
try this... Get a temporary new number first
after the activation is all done, then you can either use My Account , Profile and request Transfer, or you can message CS agent and ask them to manually do it for you
11-06-2023 10:00 AM
I used the app to activate. But always stuck in step 5 whenever "Transfer Number" as it keeps saying the number is invalid Canadian number (I used this number for 10 years).
11-06-2023 09:57 AM
HI @lehuutai130 Telus number for sure able to port into PM, but that error sometimes means the the porting request already submitted, maybe you tried couple times already
I think it is best to open ticket with agent and let them check for you
11-06-2023 09:57 AM
let us know...did you use the app to activate the account ? Use of the app for activation is req'd.
