11-30-2023
11:14 AM
11-30-2023
05:53 PM
computergeek541
Subject says it all.
I bought a new phone after signing up with PM, using an eSim. How do I transfer my eSim from one phone to the other?
I tried contacting support but that tells me to put in a ticket. I put in a ticket but I have not been able to find the open ticket I submitted. I put in the ticket last night and did not receive any sort of email confirmation.
This should just be an option in the self-serve menu with text confirmation. It feels unnecessarily difficult for customers and a waste of resources for their customer service team.
05-24-2024 03:56 PM
If I get a new esim on my new phone, will this be a new number or my existing one?
12-10-2023 12:34 PM - edited 12-10-2023 12:38 PM
@Notsheldon Completely agree. eSIM transfer to a new phone should be free. Just one of several quirks here that catch some folks. I recommend this to ameliorate the annoyance:
Take 3 before using SIMon.
11-30-2023 11:59 AM
You cannot. You would need physical SIM to switch from phone to phone...
11-30-2023 11:25 AM
to contact a CSA, best to use this link...
watch the little envelop icon on top right side of page will be highlighted when they respond to you.
11-30-2023 11:24 AM
@Notsheldon You will need to re buy a eSIM download the app on the new phone you have and log into your account and go to subscriptions add on page notice at the bottom is says shop sim now select it and choose eSIM , download and install it that’s it
11-30-2023 11:21 AM
Ok but if they didn't have a solution to keep the convenience factor, like I have in the last bit of my post, PM should have realized they weren't prepared to support eSims properly.
11-30-2023 11:21 AM - edited 11-30-2023 11:21 AM
You can’t transfer eSIM from one device to another. You need to purchase a new eSIM for $5 on second device.
Only drawback with eSIM not like a SIM where you just pop it out and put it into another device.
11-30-2023 11:16 AM
different phone requires a different esim...that's the downside of esim whereas hard sim can be transferred to different phone.
