I bought 200mb but I didnt get them
matty
Hey there, 2 days agow I bought 200mb data (10$) but i cant use them, what can I do???
matty
Thanks you very much Luddite
Luddite
Login to your account and look at Available Funds. It is likely $10. If so, just purchase the add-on again using Available Funds. Logout, reboot your phone and check for service.
When you try to buy an add-on the system only adds the required amount to your Available Funds which then means you must return and buy it a second time with Available Funds. It's a glitch in the system.
If that does not work, you will need moderator assistance. Send  a private message to the moderator team with your phone number and an explanation.
MoreYummy
Does your data ever work before?
How about your call and text service?
Have you setup https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/APN-settings/m-p/30197
