12-21-2023
02:07 PM
12-21-2023
04:39 PM
computergeek541
Bought the service, put the sim chip in connected to wifi pressed ok tried to transfer number didnt work now ive been just stuck on a page that says to contact customer support then an agent directed me here. Please help. I bought the $34 for 40gbs deal.
12-21-2023 02:09 PM
HI @Tyler000
it might be an activation problem instead of porting if you stuck at the activation page
for porting, call Porting team for update. I will send you the porting team number, check your Community inbox
also, submit ticket with CS agent and ask them to confirm
12-21-2023 02:09 PM
Same here plz help
