5G
12-20-2023 10:52 PM
Is it true that Public Mobile 5G is different from say Telus/Rogers/Bell 5G?
Service
12-21-2023 02:15 PM
Actually Telus is the only one from the Big 3 that I haven't seen with a 5G+ icon yet. On Rogers and Bell, the icon is currently only showing when n78 is being used.
12-21-2023 12:13 PM
@sheytoon wrote:PM subscribers can use n78 if their phone supports it. There is no restriction from the network.
However, many popular phones will treat a Telus SIM differently than a PM SIM. You will likely not see 5G+ icon, even if you are using n78.
so, Telus offer its 5G+ service solely on n78?
12-21-2023 01:31 AM
A good example is how some 5G compatible Samsung devices from a fear years ago have the software disable 5G networks whenever a Public Mobile SIM card has been inserted.
12-21-2023 01:27 AM
12-21-2023 12:36 AM
My Telus 5G+ plan is up to 2Gbps, whereas PM offers up to 250Mbps. Having said that, I've never personally experienced much faster than 250Mbps on Telus.
12-20-2023 11:39 PM - edited 12-21-2023 12:12 PM
12-20-2023 11:25 PM
yes
PM only has access to the slower bands for 5g. Telus has higher frequency bands(3500mhz n78)
12-20-2023 11:23 PM
Only thing that will be different is that Telus/Bell/Rogers will also offer 5G+.
12-20-2023 11:03 PM - edited 12-20-2023 11:04 PM
Hi @muffin_top,
PM uses the exact same networks as Telus and Bell depending on the location 🙂
12-20-2023 11:02 PM
PM uses the same 5G network as Telus and Bell, so, it's same
With Rogers, the 5G bands are different
