06-16-2024
07:32 PM
06-17-2024
12:19 AM
computergeek541
I have a SIM card already from Fido, and I want to continue using it. But I noticed my SIM card numbers are different, and I don't know how to enter those numbers to complete my subscription. I can show a picture of my SIM card.
06-16-2024 07:44 PM
Thank you for reminding.
06-16-2024 07:43 PM
You need to use a new Public mobile SIM card, none public mobile SIM cards or previously used public mobile SIM cards can not be used.
06-16-2024 07:38 PM
Normally you would not want to post your Sim card #. But since that is not a Public Mobile sim card it's probably not going to harm you unless you use it with that provider. All Public Mobile sim cards start with "89122" followed by 14 other digits. That one will only work with that particular provider.
06-16-2024 07:36 PM
@Niki2 Every carrier has their own sim card, you would need to get a Public Mobile sim card either direct from PM (which can be slow) or go to a Telus/Koodo store (call ahead for stock) or order from Amazon.
