3 hours ago
I have two public mobile accounts. One for my sons phone and one for mine. When I was setting mind up, I accidentally sent my phone number to his phone. Is there any way that I can transfer the number to my phone from his phone? Thanks
43m ago
Is there a way to find out what the plan options available to us would be before going this direction?
2 hours ago - last edited 2 hours ago
@Daisy6 wrote:Thank you. I sent a message to a CS agent.
This isn't something that a customer support agent can fix, at least not without steps being taken on your and son's part as well. Public Mobile's customer support agents will not swap the phone numbers between accounts, so this means that yes, you're going to have to switch SIM cards for both of you to have the desired phone numbers.
You will need to take your son's SIM card and use it for yourself as that has your phone number. A new SIM card will need to be purchased for your son to use (to replace the account that current has the eSIM). As for the plans being different, a plan change can be scheduled, but the chocies of plans won't be same as those that are offered to new customers.
2 hours ago
2 hours ago
It won't be that simple. He has a physical sim as he has a flip phone and I opted with an esim, so I can't just transfer that to him because it is not compatible.
Could I put his sim card in my phone and then get him another sim card? and reset his account. We also have different plans so the plan is probably connected to the sim, so that wouldn't work either.
2 hours ago
@Daisy6 wrote:I have two public mobile accounts. One for my sons phone and one for mine. When I was setting mind up, I accidentally sent my phone number to his phone. Is there any way that I can transfer the number to my phone from his phone? Thanks
If you are both using physical SIM cards, you can switch SIM cards with each other. If you're using eSIM cards, both accounts will need a new eSIM assigned. This can be done from inside each Public Mobile self serve account.
2 hours ago
@Daisy6 You're going to need to connect with a CS agent as they will have access to your account. You will need to open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
