Hurricane Fiona one time GB boost
Lovejeannie
Hi. It doesn’t show where you enter the code they provided. Also I already added a bunch of add ons this past week. Can the credit be placed retroactively?
8 REPLIES 8
MACKA_SPLAFF
@MACKA_SPLAFF what area code is your phone number??
MACKA_SPLAFF
dust2dust - I already did as you mentioned, but it highlights as an invalid code.
Remember
@Lovejeannie
check the update browser, open incognito mode,clear cache,cookie. try send again
link is works
Those add-ons will stay on your account for when you might go over your plan data. You could choose just to keep them. They don't expire. You don't automatically re-buy them.
Lovejeannie
Thanks. I’ll do that
Remember
@Lovejeannie
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot. ask them to
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
dust2dust
Log in your account and go to Plan & Add-ons and scroll down.
