@ Help
JK_
I got a new plan $40 5GB unlimited call and text ect, forgot to add prom code for the 12 months
darlicious
@JK_
If you procrastinated about submitting a support ticket to have the promocode added then ask them to add the promocode 2GBBONUS instead. It has no expiry vs 12 months.
JL9
Don't be too concerned, this happens a lot a CSA can manually add this for you. Just tell the promo code as the 40 plan should definitely qualify conditions wise. Private message would prob be the best route.
hi @JK_  you meant you just activated?  you can try to open ticket with CS Agent and they likely will be able to add it back if the promo is still on
to open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
dust2dust
Click on SIMon chatbot down below and find your way to submitting a ticket for support.
