01-26-2023 06:25 PM
01-27-2023 07:35 PM
@hairbag1- I believe you are correct. There doesn't seem to be a way to actually remove the card. You can only edit or disable. 😞
01-26-2023 07:07 PM
@hairbag1 wrote:@Anonymous
is it still possible to remove your credit card info from the accounts ?
Looks like I can add new card...but I can seem to find where to remove all my cc info.
Only a CSA can remove a card.
01-26-2023 07:06 PM - edited 01-26-2023 07:07 PM
@Anonymous
Looks like I can add new card...but I can't seem to find where to remove all my cc info.
01-26-2023 07:05 PM
01-26-2023 06:33 PM
@jjoyonty9 Your welcome we are here to help , have a great day
01-26-2023 06:32 PM
Thank you all for your quick response.
01-26-2023 06:29 PM - edited 01-26-2023 06:29 PM
that entirely depends whether it’s your preference to terminate all mobile services or move your current public mobile phone number to another mobile service provider.
if the first, just remove the associated payment card, and the account will go into suspended status, and eventually terminate.
If it’s the latter, when you port your number to a new provider and respond, yes to enable the port to occur, it will finalize your public mobile account.
01-26-2023 06:28 PM
Hi @jjoyonty9
Login to your account just go to payment and Disabled payment,
after 90 days your account will deleted,
01-26-2023 06:28 PM
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can also login to My Account and go to Payment page -> Manage Payment Method, and then disable Pre-Authorized payment. PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
01-26-2023 06:27 PM
@jjoyonty9- Just remove your credit card information from your account, and the account will go into suspension on your next renewal date. 90 days after that, your account is closed and your number is lost forever. 🙂
01-26-2023 06:26 PM - edited 01-26-2023 06:27 PM
@jjoyonty9 Log into self serve an disable auto pay or port your number out and it will automatically close account
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
