No Service
MWBW
I have a No Service message on my phone. I have tried many things to reconnect with no luck. Public Mobile is checked under Network Selection but not connecting.
17 REPLIES 17
MWBW
Thanks, I've submitted a ticket for PM support.
@MWBW  So hubby SIM works in your phone ,now try you SIM in his phone to rule out if it’s your SIM or your phone
@MWBW wrote:
Yes it does.
@MWBW So your SIM works in your husband's phone but not your phone.
You were having services working before this on your phone?
Is this a 'new to you phone' ? Did you check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/ as already suggested above?
My husband has service but for some reason I don't.
@MWBW your husband on PM too?
Perfect if so.  Swap the 2 sim cards between the 2 phones and see if that works.
If your sim on your husband phone still does not work, and your husband sim on your phone works, that confirms it's your sim or account and not the device, then the next step would be to open ticket with PM support
MWBW
And no, it isn't a new activation or port.
MWBW
Yes it does.
dust2dust
Maybe have a look at devicecheck.ca just to rule that out.
And yes try your sim in his phone and his sim in your phone.
@LoveNature- I'm also baffled how you divine that the customer is only having trouble with texting.
@MWBW  Did you just activate your plan or port number over ?
edit does you husbands SIM card work in your phone ?
MWBW
Hi, thanks. I've tried all of these suggestions with no luck. My husband has service but for some reason I don't.
Hi @LoveNature OP has trouble connecting, definitely will affect call and data services.
But can you help me to understand the technical details how  "go to message app and clear cache/ clear data" help connecting??
LoveNature
Hi @hTideGnow
i think @MWBW  has call and data service, but has issue with Text SMS,
Hi @LoveNature it is "no service" message that OP got, and not "no message service", clear message app cache won't help
LoveNature
@MWBW
if you have device run android, go to message app and clear cache/ clear data/ reboot phone.
hi @MWBW try to set your network to 3G only.
Try use another phone, it could be device problem
Try the phone in another place, could be network problem
@MWBW  check
Outage   map in your area:
https://istheservicedowncanada.com/status/telus/map
LoveNature
Hi @MWBW
turn off device take out SIM card and insert back.
@MWBW did you check if your service is Active?  login to My Account using Incognito mode and check
if active, try to reboot the phone once
if still fails, try your. sim in another phone.  If you don't have one around, try to reseat the sim card
