06-18-2024
01:45 AM
06-18-2024
08:29 PM
Dunkman
If I have a SIM card from another provider, how can I transfer to public mobile and continue use my previous phone number. I know I need to get a public mobile's SIM card first. And then, how do I make my previous phone number match the new SIM card?
03-08-2025 04:28 PM
Unfortunately you need to contact Bell and get them to activate a new SIM on your old account because you need to reply to the text with YES confirming you are porting over to PM to complete the porting process. Or keep the new number if you don’t want to go through get a new SIM with Bell.
You can only do a verbal confirmation if your previous carrier was Telus or Koodo. They can track down your old account.
03-08-2025 03:10 PM
Hi,
help…I actually lost my phone with previous provider that has the SIM card. So when I registered, I took a new phone number from PM as it said I could change it in my account after I activated my account…so can I now call my previous service provider which is bell and explain I want to port my number to PM.
yur assistance is appreciated.
Norm1453
06-18-2024 06:06 AM
During the activation process, there will be an option to transfer your number from another provider.
It is at that stage in the process you identify the prior phone number and the prior account number to allow that transfer to occur.
You're only role in this is to ensure the prior provider service is still active and you respond yes to the port authorization text that they will send you within 90 minutes.
06-18-2024 04:21 AM
If you are porting your number from another carrier to PM. Follow these instructions to a tee:
The steps must be followed in exact order if you are porting your number over to PM:
